Losi - Desert Buggy XL-E
Jeu 23 Mar 2017, 18:34
Losi vient de sortir une version électrique de son Desert XL.
Caractéristiques :
Scale:1/5
Length:33.25 in (844mm)
Width:19.75 in (501mm)
Height:12.12 in (308mm)
Ground Clearance:2.75 in (69mm)
Wheelbase:21.75 in (552mm)
Weight:27.5 lbs w/o batteries (12.5 kg), 30.5 lbs w/batteries (13.8kg)
Chassis:4mm Plate, 6061-T6 Aluminum
Suspension:Independent
Drivetrain:4WD
Tire Type:Maxxis Creepy Crawler
Motor or Engine:Non-Sensored Brushless, 57 x 114mm
Speed Control:Dynamite Fuze 160A
Radio:Spektrum DX2E 2-Channel with AVC
Servos:Included
Batteries:14.8V 5000mAh 50C 4s LiPo Recommended x2 (Not Included)
Charger:Not Included
Gear Pitch:1.5 Mod
Kit/RTR:RTR
Shock Type:Aluminum, Oil-Filled, Coil-Over Spring
Body:Screened Desert Buggy
Ball Bearings:Full Ball Bearing Drivetrain
Experience Level:Intermediate
Recommended Environment:Outdoor
Is Assembly Required:No
Caractéristiques :
- No-hassle 1/5 scale electric
- Flip top cage
- LED light bar
- Dynamite 800Kv brushless power system
- Spektrum™ AVC® technology
- Revised shock package
- New wing and wing mount
- Waterproof electronics
- Chassis brace plate
- Aluminum center differential
- Updated body panels and driver interior
- New molded foam insert
- MAXXIS Creepy Crawler tires
- Includes Spektrum DX2E transmitter with AVC adjustment
Product Specifications
Type:4WD BuggyScale:1/5
Drivetrain:4WD
Servos:Included
Gear Pitch:1.5 Mod
Kit/RTR:RTR
Re: Losi - Desert Buggy XL-E
Jeu 23 Mar 2017, 20:28
héeee pas mal du tout !!! ça doit arracher, j'aime bien
je sais pas si c'est la même marque mais Maxxis est une très bonne marque de pneu de VTT
